DWinTX
Is The Ram Man still in business? I want to get one of his disc brake conversions but I've called him several times over the last two weeks and no one answered. I also left two messages on his answering system, and he has not called back.
I wanted to go with the Disc-O-Tech type swap using the A body parts. In Ehrenberg's article he says Master Power sells the spindles, but I couldn't find them on their site outside of the kits. I found them at MagnumForce for $440. Is that the cheapest that they can be had? I'm guessing salvage yards are pretty much picked over at this point.
Also, I wanted to go with the 11.75 rotors. Is it just the caliper brackets that determine which rotor sizes you can use? Where else can I get these if the Ram Man is a no-go?
Thanks.
Thanks.
