cbodybob
- 11:45 AM
- Jan 10, 2014
- youngsville, NC
Pretty much all I have is pics of it in the shop & on the trailer for now.more pics please and glad your happy with the progress,avoid the walls at all cost.
It’s named aptly. During the Resto it was two steps forward & 1 3/4 steps backwards. Car is originally out of eastern Tennessee. It was raced in Georgia, Tenn & NC that I’ve found out so far.thanks looks like a monster.
on my car it 1 step forward 2 steps back.
I completely forgot to check the front shocks while working on the car. They where worn out completely. Front of car started bouncing very bad. I just made drive down passes to check steering (all new from box to steering wheel) & brakes (all new master & rear wheel cylinders & lines). Just wanted to get a feel for all of that before I made a hard pass. Was not worried about times yet. There was a lot of rear end & suspension issues I had to correct. Installed a completely new rear in the car. It’s a long story. Hope to take car out again very soon. I’ve fixed a lot of the issues & lowered the car 1 inch. New slicks on the rear. It should do better.what did it run ?
why was it such a handful to drive ?
(almost crashed on an easy pass)
more details needed
ET/MPH, weight, combos, engine, trans, converter, gearing etc.
what is the final planned outcome, et/mph etc. ?
I’m still running the factory spool mounts. I don’t see any need to change those at this time. I did install Polyurethane K frame , torsions bar support & leaf spring bushings. Not hard to do at all. Can’t say if or how much that helped as I didn’t run the car before.Hey Bob, I think we talked a few times in the past. Can you tell me anything about the motor mounts, k frame isolators, and frame ties you used? (Assuming you did) . I would greatly appreciate it. I have one of these mid 70's B's going together. Would love more pics too! Thanks!!!
Not frame tied or any additional support?I’m still running the factory spool mounts. I don’t see any need to change those at this time. I did install Polyurethane K frame , torsions bar support & leaf spring bushings. Not hard to do at all. Can’t say if or how much that helped as I didn’t run the car before.
Not yet, but I likely will in the future. I have the 8 point roll bar welded in. That’s enough for now.Not frame tied or any additional support?
