Dibbons
- 4:04 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
About 400 lb/ft torque.
Its for bragging rights and to make sure it wont blow up the first time you jump on it.Am I the only one that finds dyno tests boring?
Nick typically uses it for "quality checking" his rebuilds (looking for issues on the stand versus installed in the car),Its for bragging rights and to make sure it wont blow up the first time you jump on it.
245 netIIRC the 72 was fated at about 270 ponies NET so 335 on the dyno would be about right.
I can see the reasons for doing it, just not for watching it.
We've had a bunch of fun days at the dyno. The sounds and the smells of actually being there are something. Talking with and listening to the crowds watching. Says one guy, "Wait that can't be right! The car with one carburetor made more horsepower than the the one with two carburetors!"It’s similar to putting a combo together for the car, with a specific ET target in mind.
Without going to the track you don’t know if your combo meets expectations or not.
For me, the dyno results are a similar thing.
Most times there is a power expectation for the build.
In addition to being able to break it in under controlled conditions, check for leaks, seat the rings properly, etc........ you also get to see if the combo of parts you selected meets the target power output....... or not.
I have done many many dyno tests where the dyno test was the focal point of what ended up being a great motorhead social occasion.
I’ve had a lot of great days at the dyno.
