Anyone know what this hole is for
koosh
2:09 PM
CT
69 Coronet Super Bee….
Is there an adjustment screw in there? If so, what is it for?
It an adjustment to tilt the window in or out. I think. I’ll look at mine and report back.
No, it's an access hole for the allen socket head screw and nut "block" that locks the vent frame between the front and rear door panels.
Koosh, you need to spend a few nights reading through the restoration threads members have posted here.
It holds the window assembly in place. No adjustments. My bad. You have to loosen it to remove the assembly.
You loosen that Allen and other fasteners to adjust the wing frame in the door.
Thanks guys… I tightened it up, no more rattles.
As far as going thru restoration threads, why not just ask a quick question?
Got my answer here in minutes.
While we are on the subject, does anyone reproduce the plug?
Because if you took a few hours to do so you'd know how the entire assembly and a lot of other components go together and function. Carry on...
Then you pros would have nothing to do…..:)
Totally fine to ask. "Most" are happy to help and search doesn't always find the information needed. By the title of your post, i'm just glad we didn't have to teach you about the birds and the bees.
:lol:
