- 1:15 PM
- Nov 21, 2008
- In GTXtacy Illinois
Just BEE careful
Did it yesterday - Went better then expected - Hardest part was figuring out how the air cleaner assembly gets removed LOL
Did not buy the special locking tools - Used a snap ring pliers for the tensioner - Did not remove the vacuum pump
Went with a Mopar Timing Belt - Was marked Gates - Factory tensioner was a GMB marked on back of bearing
Take your time , mark the crankshaft , mark the camshaft gear , precise , YOUR MARKING BOTH GEARS TEETH WHERE YOU DECIDE BEFORE REMOVING THE OLD BELT , then I continued the marked after the factory belt was removed - It’s either aligned or one tooth off after installation , saw zero reasoning for loosening the camshaft gear
Do your rotations for alignment of teeth and marks
Do your rotations for tensioner and proper tension
Factory belt did not look so good after 105,000 Miles - Peace
Make sure you follow the same procedure when you have to replace the WP in about a month!! You ALWAYS need to replace the WP when the TB runs it...I finally got mine done at 113,000.
Followed most of the pdf @Bee1971 provided.
I did not remove the vacuum pump gasket, and it appears to have resealed.
I did use the $35 locking tool kit.
I also did not replace the water pump, as I don't like to tempt fate like that.
...and I did not loosen the cam pulley, although I do understand why that is part of the procedure and kind of wish I had done it.
I'm now at 115,500 and so far all is well.
Be advised you do need an "external torx" socket for the motor mounts.
That caused a one day delay for me.
Harbor freight has a nice deep set, Auto Zone has a cheaper, smaller, lesser quality short set.
You can also pop a few offending rockers out.The overhead cam 4.7 dodge V8 is kind of the same thing but it's chains. The cams want to turn off of where they belong without the chains being on the sprockets. They make a tool set to hold them in position or like most, use vice grips. What a set up!
Could it Bee a ground somewheres?Glad I didn’t pull the vacuum pump , or bought the tools
Saw no reason to unless the belt broke or skipped a tooth
Anyways , passed 115,000 miles now
Fingers crossed for 200,000
Survived another WI Winter
Have had a few codes pop up this past winter
One was for a wheel speed sensor - Damn dash lit up with enough lights
Another was a turbo boost code - That one got me a little worried as power was down for a day
Both codes cleared and zero issues in the last few months - Still scratching my brain
Another weird issue is the cruise control won’t turn on every once in awhile , after it was on and then turned off , won’t come back on until the car is turned completely back off
Manual transmission
Car runs great though LOL
I’ve taken that same gamble 3 or 4 times, so far I haven’t regretted it.It's already been two months.
If it wasn't bad before, why would it be bad now?
That's just a preventative maintenance option due to the disassembly time involved.
I chose to trust the OEM pump versus a replacement.
Manual transmission
