65 dodge 65
Hi All
New at this-i have a few question to ask-i put a 413 together bored 60 over with max wedge stage two intake heads and manifolds
2800 stall converter-motor sounds great-i have a 528 lift hyd.purple shaft cam-when i put it in gear setting (wheels)on the floor- motor stalls out when i put it in gear with foot brake on--
i put it on the jack stands -not holding the brakes-put it in first gear shifts fine though the gears -but when i hit the brakes motor will stall out-like the converter is to tight.any thoughts on this thanks for your time thanks jack
