1965 Belvedere II 318 poly tuning
Something is not right. There should be constant vacuum from the manifold port at idle and no vacuum from the ported vacuum nipple until you open the throttle.
This brings me to my confusion. Something is preventing the vacuum on the non ported line during idle.
The man vac port will be the lower one on the carb body. Nothing to do with the brand of carb either, Holley or Carter [ Carter is better ]. A little known fact is that the engine can need as much as 50* of idle timing with big cams, & anywhere in between. The simplest/best way to do this is by using vac adv connected to man vac adv [ MVA ].
The 264 cam with 9:1 CR is probably going to need 25-30* of idle timing for best idle/highest vacuum/best tip-in performance.
You can test this easily in 5 min: engine warmed up, VA disconnected, idling, in gear if auto, turn dist SLOWLY CCW. Keep going until you get the highest rpm. Now see what the timing is.
Report back with results.
Thank you for all the info and I will definitely head this direction.... However my question still remains as to why the ported and non ported vacuum ports on my carb do the exact same thing. Manifold should show vacuum at idle but theres nothing until I open the carb and if thats not working properly is there something wrong with it. I've always been a Holley guy and this is my first Carter so don't know if this is a known issue or an isolated case.
The only thing I can think of is....you have the wrong port. The #9635 carbs had an EGR port...as well as PVA & MVA. Maybe you are plumbed into that?
These are the 2 vacuum ports I'm talking about. On mine they both act the same way which doesn't seem right to me.
I wonder if your metering rods are lifting high enough that it's dipping slightly into the main circuit thus pulling some vacuum into the ported circuit nipple?
one needs to run as much initial as can be tolerated by the engine, then limit the mechanical weight slots so there is not too much advance that pinging/detonation occurs.
then tailor the vacuum advance curve to get the maximum advance possible under cruise conditions [very light load] as possible.
E-booger did an excellent article on this very subject in Mopar Action magazine many years ago, and if one follows his suggestions, quite an improvement in engine performance can be obtained.
i really recommend one read this article if possible.
just my opinion. [and i'm old, so don't beat me too hard !]
your mileage will vary.
:drinks:
:drinks:
Now we're gettin somewhere
Post #26.
If both ports act the same [ & you have them correctly marked ], it is most likely that the pri t/blades are open too far, exposing the P port to vacuum at idle.
The carb needs to be removed & the T slot position checked. Should not be more than 0.060" at idle, & I am expecting it will be more than this.
Until you get this relationship [ the amount of T slot showing below the blades at idle ] correct, you will never get the carb/ign tuned properly. Ideal amount of T slot showing is 040-020, & 020 is better.
Post #26.
Thank you for the advice however I am not getting any vacuum at idle from either port. I did a little internet digging and from what I heard the manifold vacuum port on the "competition" series carter carbs that line is blocked off and to use a drill bit and ream it out. I'm all about doin crafty modifications to parts but don't want to do anything to make the issue worse.
To make matters worse....there are two lots of 'Competition Series' AFB carbs. There is the later #963X for GM, Ford & Chrys.....& the original #4758-4762 carbs. There should be no reason for these vacuum ports to be blocked...unless purposely blocked by someone.
Take the carb off and inspect where the M port leads to and if it is blocked off or not.
Thank you very much
Ok so little carb update. I haven't seen this routed like this before but it appears that this specific model of carb has no manifold idle point within these ports. In fact the "Ported" vacuum side (pass side "left" of carb, higher nipple) is lower in the chamber than the "manifold" vacuum port.
-First pic is at idle
-Second pic just slightly open
-Third pic wide open
At idle neither vacuum port has vacuum (and I'm talking about the 2 small ports on the front only)
Just curious if any one else has this style of carb? What are the benefits of it? I know the part number is set for a GM SBC, not sure if that has anything to do with it but ya never know... unless you do.
- In post #26, look at the port marked M. That is manifold vac [ or should be if it has been drilled through ]. See how close the port is to the inner mounting hole? Compare that with the casting cut-away of the base in post #35.
- make sure the carb gasket covers that opening, on the carb & the intake.
- T slot looks perfect
- the two ports marked P & M in post #35 are Ported & EGR, but maybe one is not drilled through? Neither are manifold vacuum because they are above the t/blades at idle.
Right but I cannot find anything that explains why the manifold port that is on every other AFB carb is not that on this carb. Just wondering if any one else has seen this or bought a carb specifically for this feature.
It doesn't matter why, or if anyone else has seen this. It just is that way, so use it or Replace it. That's the 2 choices right now.
I appreciate the response and you are correct that I do have two choices, however it does matter to me as to why and if anyone uses this style. I am a curious person by nature so I like to get answers for things that puzzle me. Maybe there's a benefit to this that I am unaware or if someone is looking for one and I have it... My brain doesn't allow me to just stop being curious when I don't understand why and especially when others can't explain it either.
