1967 Plymouth rear shocks coil assist
440Matt
6:27 PM
Wisconsin
Are the Belvedere and GTX rear shocks compatible. Most coil assisted shocks are listed for the Belvedere and not the GTX
Anyone know if the Belvedere rear shocks will be a direct bolt in for my GTX with the dana 60, thanks, Matt
Standard coil assists are for try to keep the car level under load if that is what you are looking to do.
Be careful of overloading the upper shock mount.
If you want to raise the vehicle, spring replacement is the proper way.
Thanks but is the std belvedere and GTX using the same shock
If you're asking if the two models' rear shocks are physically the same size/mounting type,
the obvious answer is "yes" - which can be quickly researched on any parts website that sells shocks.
Are you asking something more specific here?
No, thanks, had trouble cross referencing so i can here
