I'm happy for you.
Oh yes we are! Tackar..Are we gonna see it out on the street this year? Awesome work on the car! kör hårt!
It came out of a Pro Street -68 Charger that my dad owned for some years. Worked flawless there. Sitting for 4 years until now.Congrats on getting it fired up
I don't recall the history of this engine and hard to hear really what's going on but have you checked valve lash? Almost sounds like the valves are tight.
Have you connected a vacuum gauge?
Yes, you are correct, there is a lot of corrosion and I'll have to replace it but I was planning to do that when it's time for the efi conversion. It looked like this when it was in the previous car also and we didn't have the popping then. I'm going to check CO when I get home again. Away on a business trip to Netherlands this week..Looking at the last picture of your distributor there's a lot of corrosion and rust on the rotor. That's a sign of moisture. Does the inside of the cap have corrosion? What's the pickup look like? This could be your popping.
The last time I had a popping like in your videos my new plug wires were slipping away from the plug. It was just a small gap but that's all it took.
Yeah...I would have been running down the street screaming, stripping my clothes off about halfway through that, and I repair medical equipment!Chaos and Mayhem but almost completed. Looms with connectors are done, wiring diagrams completed, just need to wire up the buttons.
Everything is connected with quick connectors so it's easy to remove all panels without cutting.
I had them off when I squeezed it in between the frame rails from underneath and it all looked fine and dandy. It's a Holley demon carb. Checked floaters and adjusted levels, looks good.My Barton Hemi fires in the pipes when cold and then clears up as it gets warm. What carbs are on the car? Have you recently taken the valve covers off to take a look under the skirt?
Thank you for the kind words!Man, this is truly going to be a real
work of mechanical artistry when you are finished.
With my budget and my mixed use, mixed "genre" I can only emulate or approach the levels you have attained. I have some of the same parts as really expensive cars, and a similar "theme" as some others, but you are putting together the WHOLE PACKAGE and it is AWESOME![]()
