1969 Charger correct engine
desrocp
New Member
5:30 AM
canada
Currently rebuilding a 69 Charger and want to drop the correct 440 in it. I was told that the production perion for the B bodies was from August to August. I found a 440 block with a date code of 10-28-69. 25364306 does this mean that engine is incorrect for a 69 since the engine as built after august?
Any help would be appreciated
In my experience the block casting year was the year prior to the car year and rarely have I seen a block cast the same year as the car. Actually it could be several months prior if you look at the month it was cast and compare the scheduled production date of the car. The SPD date is found on the fender tag and you will need one of Galen's books to decode it, or post the tag here and 6 people will chime in. What is the stamp pad say on the block? For an engine that was installed in a 69 car you should have E440. Also 69 cars had the VIN stamped on a machined area by the right side oil pan rail. Usually it's the year, the assembly plant code then sequence number. I.E. 9B123456. The block you found is probably for a 1970 model year car and should have F440 on the pad by the distributor.
