1969 steering column shaft length manual steering
60Nina
10:43 AM
Missouri
Hello everyone
I am needing to know the correct over all length for a manual steering 69 roadrunner
4speed steering column shaft? Will a shaft out of a 1970 manual steering floor shift work? Any info would be greatly appreciated.
The shaft length only varies from power steering to manual steering as far as I know. You should be good to go!
Hello everyone
From my notes on 68 & 69's, because those are the only ones I have rebuilt. I would think 70's are the same?
Power steering shaft 41.5"
Manual steering shaft 44.5"
Outer column 31.25"
Tube between shaft and column (power and manual) 30 7/16"
Good info. Thank you. Been away from the site for a bit!
