Wing It
- 3:37 AM
- Aug 23, 2020
- Castro Valley, Ca 94546
Thank you for reading my post.
I have a 1970 440 4BBL that is a 9.75:1 motor with a slightly larger than stock cam and slightly bigger valves, and running a stock 4BBL. I have seen posts about using a carb spacer to try to avoid the fuel from boiling out of the float bowl. I also have seen posts about blocking the heat riser by using a valley pan/intake gasket with no passage in it. I understand this will render my stock well choke useless. I have already rebuilt the heat riser on the right exhaust manifold and I prefer to have a working choke. The car is a matching number Superbird so I am trying to keep is a original appearing as possible.
My question is this. If I stick with a functioning heat riser and choke but used a carb spacer with my engine specs will I experience boiling fuel or any other similar fuel problems? What thickness carb spacer should be used?
