FOUND 1973 Charger Combination valve
daytona71
5:06 AM
BC
Looking for old/used Kelsey Hayes combination valve KH89410 for parts. The small ring that pushes against the long spring in the lower assembly(rear brakes). Mine took off into garage someplace
Thank you
I'll take a look should be a few porp valves around here
Can you post a picture of the valve. Just so I know witch it is I've had 3-4 part outs not long ago 72-74 so should be a few here
Here is the combination valve that I am rebuilding. I need the little shouldered washer that goes between the cap and the spring.
Thanks to all who searched for the part I needed. The missing part returned. (it was hiding on the bottom of an open paper bag)
