1973 Dodge Charger Radiator
Rusty
12:15 PM
Texas
I need to replace my radiator, motor is a 340 any recommendations on bolt in replacements? I see Summit lists a few aluminum units but does the shroud still fit and are they truly bolt in?
I just put a 26 inch champion in mine. It almost bolted in, had to drill 2 holes 1/4 inch higher and original shroud won't fit. Works great though. I have my original 26 inch 3 core with shroud if you are interested., No leaks I just wanted better cooling. Should fit your car, 150 plus shipping if you are interested.
Try Wizard, radiator will fit in stock location without any modifications, and stock shroud mounting as well.
