1974 GTX
Does anyone know where i can buy a proportioning valve for 1974 RR GTX. Can a proportioning valve from a 1972 RR be installed in my 74? Factory disc/drum car
Thank you for your response. Is there a manufacturer for this Texas style? or is that the manufacturer?Does anyone know where i can buy a proportioning valve for 1974 RR GTX. Can a proportioning valve from a 1972 RR be installed in my 74? Factory disc/drum car
Thank you for your response. Replaced the entire brake system with exception of the proportion valve since i have never had an issue with one in the past. Car sat for several years outdoors before restoration. Can't get fluid to rear wheels, tried to clean it but have not taken it apart yet.74 will have a much different mount bracket than 72 and even 73.
What is wrong with yours. They can be rebuilt. Mainly needing a good cleaning and new O-rings.
I might still have a 74. I'll check
Let me know if you come across it. thank you74 will have a much different mount bracket than 72 and even 73.
