a 2.4 rear gear? im pretty sure the highest was a 2.76 ,but any way i would be looking at an 8 3/4 for that kind of ratio. 8 1/4 rears are not exactly the greatest for performance . i didnt know you could get a 4.56 ring and pinion for an 8 1/4
The carrier will need to be changed to a carrier from a higher gear ratio, the 2.76 carrier will do. However,a new suregrip unit is around $300 IIRC, or last I seen.
I just got my 'Doba back today from having gears installed. I purchased a used sure grip including 3.90 gear set off ebay. It reall y has made a big improvement. I had 2.7 gears original. Now to make this wretched 318 breath...
100% agree with SUPER77SE 8.75 is the way to go just get rid of 8.25.
And besides when you will want to change gears for different tracks it is a real breeze just swaping the center section.
