Dibbons
- 1:27 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
Driving my '72 Plymouth Satellite Sebring Plus up from La Paz, Baja California Sur, Mexico to visit friends and family in California. This vehicle still has the original factory stock 318 two-barrel (Carter) motor (numbers matching). Gas mileage for the first 950 miles from La Paz to the USA border in San Diego is averaging 10.7 MPG. My average speed averages about 60 MPH, but I go faster on some straight stretches of highway. Something must be wacko here.
The facts:
History
The motor was froze up before installation, so a year ago I had to do the following:
a) freed up the pistons using various penetrating oils
b) changed out all the engine gaskets and freeze plugs
c) new timing chain and cover, new water pump
d) new distributor, cap, rotor, points, condensor, wires, plugs
e) I personally rebuilt the carb (choke is wired open don't need it where I live in the desert)
f) exhaust manifold heat control valve wired open
g) new gas tank and fuel filter
h) I believe a new fuel pump
After all the above, I installed the motor (4/15) and it fired right up.
That was a year ago. After that I ran a compression check and it was pretty even.
Presently the vehicle condition is:
a) starts up immediately, both when cold (with 2 or 3 squirts from the accelerator pump) and when warm (just touch the key and it fires right up)
b) when starting it cold, a quick puff of smoke is seen from the tail pipes (clears out after about one second) don't notice that puff when restarting it warm
c) transmission was rebuilt a year ago, stock rebuild with a shift kit and performs flawlessly
d) differential is stock and open (no sure grip) 8 1/4 with around a 2:71 economy ratio (just changed the gear oil 90W)
e) tires are new and just finished a wheel alignment last week
f) timing with vacuum line plugged is about 2 1/2 degrees BTDC, dwell is within factory specs
g) oil and filter just changed, cooling system flushed and refilled, new air filter
h) new dual exhaust system that exits in front of rear tires with glass pack mufflers
Engine performance:
a) engine idles smoothly at 700 RPM and purrs like a kitten, which indicates to me the compression is good and even between the cylinders
b) driving stop and go between the stop signs/signals in town, seems to run and shift just fine
c) on the highway downhill it purrs like a kitten, on level roadways it seems to miss intermittently
d) under acceleration (more than half throttle) and whenever under load (going uphill) it misses quite a bit and sounds like crap. Does not sputter like when one runs out of gas, it misses (misses a beat). It accelerates enough to pass slower traffic, but all the missing/popping gets on my nerves.
So, taking the above into consideration, I should at least expect 15 MPG, maybe more. So 10.7 MPG is way off. (I drove a new 1971 383 automatic Road Runner back in the day with a 3.23 open rear and that consistently got 12.5 MPG) Thank you for listening.
The facts:
History
Engine performance:
