We discovered an issue with my Son's 1973 Roadrunner :sad10:. Some specs:
The problem is it suddenly burned through almost the entire crankcase of oil. One suspicion was the PCV, so we temporarily plugged the line and "think" it was OK. We then replaced the PCV and I drove it on the highway about 250 miles. It burned through 4 quarts of oil. The car generally runs OK.
Can the PCV really do this? Of course, I am worried about the oil rings and/or compression rings. I still need to pull the plugs this weekend and do a compression check, but suggestions and things to check (and potential theories) would be greatly appreciated.
Thanks in advance,
Hawk
- 340; 727 Slap Stik; 3.55 Sure Grip; Original A/C
- Engine Modifications: Edelbrock Performer 318/360 dual plane manifold; Crane Cam; 10.0:1 compression; stock crank, but balanced differently than original (on flex plate); “medium” ported original heads; larger 2.02 / 1.60 valves; headers; 2 ½” exhaust, 8qt oil pan.
- Cam Specs: Lift Intake = 454; Lift Exhaust = 480; Rocker ratio 1.5; Intake duration = 272, Exhaust duration = 284.
Thanks in advance,
Hawk
