426 crank value?
luis9995
4:46 PM
Los angeles
Hi everyone was wondering what the value of a 426 crank is? Someone I know has new ones and original used ones. Was wondering if they had any value? Some he has are boxes and labeled 440-6 for a six pack and some just say 440-6/hemi or just 426. One hemi one says std the other says 010 magnafluxed. Just looking for a rough value. Would be appreciated. Thanks
hemi cranks have an 8-bolt flange. 440's do not. Values are all over the place. Check ebay, racingjunk, etc..........
Best thing to do is check eBay watch a couple auctions see what they end at
a friend of mine just bought a steel 440 crank std main and rod for 100 dollars hope this helps
426 Hemi cranks (8-bolt) are worth more than 426 wedge cranks (6-bolt). I'd ballpark a non-hemi crank at $200-$300'ish range. Not being turned down on the mains/rods is better than a crank that's already 0.030"/0.030" since bearings aren't available any larger than that. Also, be careful if they're laying on their sides & not in a "crank crate". Cranks should be stored on end if not in a crate or they can warp over time.
