You have the wrong parts. Every 512 kit for a 440 on the website is .010"-.015" in the hole. (I've built these before.) Your block is not .070" too tall. I'm sure they will be glad to send you the correct parts.
It is. current set up has been in the car for 3 years.That stuff inyour photo looks "used" .
Attached is the build sheet from the machine shop that put together the motor a couple years ago. I highlighted the part number for the piston. According to the 440 source website,this is the correct piston. I guess it is possible that the wrong piston was sent and installed this is the correct piston. I guess it is possible that the wrong piston was sent andAfter looking at the Icon catalog, I’m going to say the engine has the wrong pistons in it.
They have a piston for the 4.375” stroke that has a C/H of 1.423”, which would put them .077” down the hole if used with a 4.25” stroke in a block that’s 10.725”.
That’s my(new) guess as to where the problem lies.
Like Mr. Porter mentioned, that 'taper' is a chamfer. Cylinder taper is from ring wear. If you notice a gap between the top of the piston, that's normal as the head of the piston has a slightly smaller diameter than the 'barrel' of the piston.Here is a close up photo of the piston (at TDC) in the bore. The taper at the top of the bore is very noticeable as is the depth of the piston in the bore.View attachment 2016325
.... and you WILL get a performance increase with a couple more points of compression!I know “if it were me”, I’d be hoping it was a case of the pistons being wrong.
The published weights for the 1.485” pistons vs the 1.423” pistons are only 13g apart.
That’s well within my comfort zone for a swap without a rebalance.
In other words, minimal disassembly required.
Front of the engine doesn’t even need to be touched.
To deck the block requires a complete disassembly, a trip to the machine shop, machining, cleaning, etc……. Then complete reassembly.
there is not too much more to the story. I purchased the car about 6 years ago with the motor already built. It had the 440 source 512 kit, edelbrock victor heads, and a cross ram intake. I raced it in NMCA events, but wanted to go faster. I made some changes but it didn't get me where I wanted to be, so it went to the machine shop for a refresh including new pistons to increase the compression. This was about 3 years ago. Yes, the invoice attached is for the work done to the motor.A bit more info at the beginning would have been helpful.
Did you have this motor built, or someone else?
The bill you posted begs a bunch of questions too.
What heads? Strange that the bill says “valve job” for an NSS motor. And “recondition rods”. New rod bolts too. We’re they new?
What is the date on the invoice?
Seems like there is so much more to this story. Are you sure that invoice is for your motor?
Thanks for the clarification.there is not too much more to the story. I purchased the car about 6 years ago with the motor already built. It had the 440 source 512 kit, edelbrock victor heads, and a cross ram intake. I raced it in NMCA events, but wanted to go faster. I made some changes but it didn't get me where I wanted to be, so it went to the machine shop for a refresh including new pistons to increase the compression. This was about 3 years ago. Yes, the invoice attached is for the work done to the motor.
Since the rebuild, I didn't feel the motor lived up to the potential that should have been there. I finally decided to take the top end apart and start checking on things and that led to this thread.
First thing to do if it's assembled is measure the stroke. Really easy you could even use a ruler. It's eother 4.250" or 4.150". If the stroke is correct my bet is the rod isn't .080" off. But there could be a combination of deck height and/or compression distance being incorrect.Please excuse my very crude diagram. I am trying to wrap my head around where the issue ultimately lies either with the block or with the crank/rod/piston. In this diagram, the piston (blue), is at TDC, the bore begins a very pronounced taper above the piston to deck height. If the issue is with the crank stroke, rod length, or compression height of the piston, the top of the piston would no longer be tight in the bore as it would now be in the tapered area of the cylinder. That doesn't seem like it would be correct, or am I mistaken?
That leaves deck height as the issue. As Prostocktom mentioned decking the block would be a viable option with some other necessary work to the intake/heads. Wouldn't this also cause an issue with valley pan fitment. One way or another, the motor is coming out and coming apart.
I think you're forced to run that intake in that class.If I remember right, weren't you struggling to get into the tens with your car? (NO offense meant, if my memory is fawlty.) [ Fawlty towers, funny show!]
I'm guessing the 60 year old design crossram isn't helping.
When I replaced my 850dp/tm7 combo with a crossram with two 750 competition carter's, my car picked up.....
NOTHING.
Further tuning would have probably helped, and the crossram definitely put eyes on the car, it just didn't go any faster or quicker.
