MRMOPARMAN
I have a constant engine noise from the top end of my 67 GTX 440. Engine has 70000 miles , doesn't blow any oil.Do I need to replace the rocker arms, lifters etc...??
It almost sounds like the engine is starving for oil at times. At hi-way speed ...as I slow down to turn off hi way the engine "Hammers like diesel" between 50-40 mph. then goes away and shows up again (less noisy) as I turn off hi-way.
Should I be using an Oil Additive ??
Should I be burning Premium fuel..??
Any help is greatly appreciated
Kevin
Kevin
