1970GTX
440 stumbles off idle only briefly but just annoying enough to want it cured. Fuel octane rating makes no difference. Engine is fairly fresh, about 5000 miles since rebuild. Retains stock bore and stroke.
1970 440 stock manifold with edelbrock performer 1407 carb
stock exhaust manifolds
Comp Cam -4 hydraulic flat tappet
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=717&sb=2
timing at 5 BTDC
idle @850
We've adjusted the idle mixture screws to no avail.
I have a rebuilt Carter 4738s carb. Do you guys think it's worth bolting that on and seeing if things improve? Any other suggestions appreciated.
timing at 5 BTDC
idle @850
