451Mopar
When I work on AFB type carbs, one of the first things I check is the float/fuel level. It is a pain because you have to pull the top of the carb off (after running the fuel pump) to check how much fuel is in the bowls. I like to see fuel even with the notch in the separator plates in the bowls.
