gto64gto
I have a 440 that I bought in Little Rock and drove to Fort Worth and then home in southeastern NC. I ran 3000 RPM and 70 MPH all the way and only used 2 quarts of oil. For some unknown reason, the engine has started leaking oil at the rear. I had the pan pulled and the rear main seal replaced. The mechanic said the old seal he removed looked good and had black silicone on it. It lasted about 15 miles before it let go again. My engine runs 70-80 lbs at idle or at 60 mph and I've never had an engine with that much oil pressure. Has anyone had the cam or lifter galley plugs leak? I am thinking about putting in a new oil pump with lower pressure. Does anyone have any answers or thoughts on this problem? It's starting to be expensive and a really big problem. I cant understand why this just happened with no previous problems. Thanks for any help.
