chargervert
I am assembling a 440 engine that I took apart about 3 years ago and the push rods are tapered down on the last half inch on one end. I cannot remember if the tapered end goes in the lifter or the rocker arm. I replaced the cam and lifters with a Comp flat tappet hydraulic setup. Should I even use these push rods at all,or replace them with a new set. I imagine that if they go in with the tapered end going into the rocker arm, then I would have to use them to run that rocker arm setup. If that's the case, are they ok to run,or should I swap out the whole push rod and rocker arm setup. Any input would be greatly appreciated. Thanks Pete.
