Artis
Is your machinest going to do the big ends with the new bolts? SPS bolts work just as well and are half the price
Is he going to hang and align your pistons and rods?
NO Way would I run an MP cam this century
what are your questions about the KB146 vs 184 I helped design the reverse deflector pistons
no way would I have a block "finished machined" without the machinist having the pistons in hand
above #41 how do you get 4.29 for pistons?
machinist have a torque plate? If not I can tell you how to fake it
have you checked valves, seats, guides, runout yet
Machinest is waiting for bolts and pistons for overbore. I never bore block w/o pistons.
Pistons and rods will be aligned (weight&height)
Which piston will be better for 906 heads? There are different piston quench pad heights ( 146 (+0.075) and 184 (0.140)) and piston head volume. Which piston will give correct CR for street use with pump gas?
#41 post is my mistake, I have STD block, who needs overbore.
No, he havent a torque plate, how can I made it?
Heads are waiting their turn to be assembled - I hope next week.
Please suggest cam. 209/502? im worry about idle.
Thanks!
edit:
My mistake - 292/509 cam
