That sucks. Like @Matthew J said... The machine shop offset ground that journal, which you proved when you saw 0.020 on the stroke. You could have them recenter the offset but that will get you way under on the journal diameter. I dunno man... I'd start with asking for a new crank and work backwards from there. That one may be toast. Very worst case have them offset the three others and use thick head gaskets. But then you start running into there pains. If you're serious about the motor... Get a new crank.
So update on this
Talked to engine shop yesterday he said he ground crank that way to save it because of spun rod bearing it was warped, which I figured was the case. He said if I bring him another crank he will grind, balance and and install on his dime.
He assured me that I would never know the difference and his sprint car engines they build are done like this all the time. I have another forged crank, but it’s probably going to be a month or 2 for him to get it ground and rebalanced.
My question is what would you guys do give him crank and wait or run it how it is? The block was bored and honed with torque plate, fully balanced and line bore checked I have tf250 heads and a custom ground cam for it
Junk the crank you have with the problem. Either take the other core crank to be re-done to him, or someone else, depending on how you feel about the deal. I probably would be looking for a more a detail focused shop and move on.
Running what you have is not a problem. It’s the compromise you’re making on piston to head clearance. You’ll need to decide if that is important to you, and if so, how much. Then make a decision.
