WesleyK
Hey guys, so Ive searched and if this is covered already I apologize I couldn't turn anything up. 68 Bee 4spd, about a year and a half ago I went through and inspected the trans during the restoration process. All synchros looked good as did everything else. put the cover back on and manually shifted through all the gears using the tabs the rods connect to. All seemed fine. Once in the car and hurst mechanism adjusted i every gear nice and smooth with the engine off. Yesterday I "drove" the car for the first time pulling it out of the shop. All was well then suddenly no reverse, then no 1-2. I unhooked the rods and could shift into reverse on the tab but the 1-2 lever is stuck it will not budge. So obviously I have an internal issue. So can anybody advise me on what to look for? I'm planning on pulling the cover first to have a look without pulling the tranny if i can help it. Any tips or procedures I'd appreciate. I want to reiterate this is not a shifter mechanism issue as I have unhooked it and it still will not move. 3-4 by the way shifts perfectly.
