5 blade to a 7 blade well it help
That's the point. Now you need ... a shroud gives 3-4 times more air flow.
HI,
OK.. I ether had the gaskets on wrong or a intake leak .. I had them replaced and without a shroud its running 1/2 way between the first mark and the 1/2 way mark on the gauge just like it used to ... So its fixed without a shroud... I checked the air flow and its moving are thru the core all the way around holds paper tight ...
HI,
Well I found out today if I stay 1500rpm's or lower it stays less than 1/2 way on the temp gauge.. I also noticed that my stock fan blade is crap metal very flexible and goes almost flat when adding RPM's to the motor.. So maybe a stiffer fan blade.. Timing is like 8 to 10* small block. cam is comp High energy, carb is QF 450. Vacuum is 14 to 15 #.
