soundcontrol
mmissile, I got that "how hard can it be" attitude also! I do need to make a decision soon though, and get started either way I decide.
I really, want to keep all my interior stock, including the shifter. I took the Charger shifter apart, trying to understand how it works, and it shifts by a wire, and there is an electronic box that seems not removable on the shifter axle, (dont wanna break it) I can peek inside it though, and there is some movement in there, probably a plastic arm that pushes some switches or an optical sensor. It should not be too hard to apply that box to my stock shifter somehow, and make it move the same distance as the Charger shifter. There is also a solenoid, that works as a parking lock, with the smaller wire that controls the pink plastic piece, don't think any of the locking stuff is necessary. It locks the shifter in park until you press the brake pedal, the parking break pedal might be involved also. Also for the manual shifts there is 2 small switches that engages when the shifter is in D, those ar easy to put somewhere on the stock shifter or in that area.
Picture 1: shows the black box, that I can't seem to get in to without removing the axle, and ruin it.
Picture 2: The manual gear switches, 2 normal switches that can be anywhere.
Picture 3: Pistol grip. :headbang:
