6 bbl choke
Then I can only say ....
Stupid Holley tech!
They told me it would work.
Monk here's an idea, don't block off the ports, wire open the Heat riser. That's what I've done to my car(4-bbl) , 3-4 miles down the road the choke is rdy to open if I blip the throttle . Still using oe choke. Heat riser spring is broke&no readily/cheap parts available.
yeah well, the heat riser on the manifold doesn't work so there you go
