in building a 64 330 its a old drag car the core support is removed and the firewall was moved back also the floor was modified . id like to take it to the track(antique drags,hot rod reunion etc) but dont know what it would be in tried looking at the NHRA rules but got a headach any help thanks
Redding Ca. www/norcalnostalgiaracing.com
has some Nostalgia races,
I'm not familiar with their org, or rules
ANRA.com maybe, not sure if they still race
they used to be at LACR
maybe Fontana, Irwindale or Pomona
maybe Ramona, east of SD/Poway area
Bakersfield/Famoso Raceway
maybe has more than the NHRA Heritage events
Sacramento Raceway,
has nostalgia events too
Sears Point/Infineon Raceway, Sonoma
use to do a couple nostalgia events a season too
But;
Check the NHRA Heritage Series/HotRod Reunion stuff
'NHRA'
Nostalgia rules
IIRC they run twice in Bakersfield/Famoso raceway
IIRC 1 time in Sacramento too
your car should fit in one of their classes
it starts at like 12.50 & goes to 7.50
A, B, C, D, E, G (?)/Gas Classes, something along those lines
I'm not sure if SCTA (Southern Calif. Timing Assoc.)
is still doing events or not
or Goodguys, both had good Nostalgia racing & specific rules
& specific year cut off etc., been a while since I did any at all
IMO it won't be legal in S/S classes
not from your description of the mods
in any of them,
you will need all the approved SFI safety equipment &
a min of a rollbar, usually a cage,
Snell appr. helmet & SFI (in date) harness
if you run slicks you need longer wheel studs & open nuts
a driveline safety loop min.
no, brake or fuel lines going across the firewall etc.
if it has headers, the collectors need to be SFI retained
good luck
