'65 Belvedere tail panel trim, is it anodized?
fshd4it
4:19 AM
Winlock, WA
The trim pieces for my car need a little polish (and definitely paint as well). Before I go at them with Mother's or something similar, I wanted to make sure if they're anodized or not, as I understand it doesn't like being polished.
All the aluminum trim is anodized. If you want to polish it just remove the anodize. I used Ever Brite after polishing mine to prevent corrosion.
Mike
What did you use to remove the anodizing? I saw where somebody did that on a '77/78 truck grille, looked like a lot of work.
I purchased a gallon of anodize remover online but, many have said Easy Off oven cleaner will do the job. It did take me more than one application to get the anodizing completely off. This can be tested as you proceed by sanding, looking for the bare aluminum "gray" slurry that indicates aluminum removal. Then the elbow grease begins!
Lots of info on polishing is available online.
Mike
Todays EasyOff is useless. It won't even clean the glass in an oven... I know because that was a task yesterday! LOL
Lye bath to strip and then hours and hours of work. Believe that I put 48 hours into my Bee tailpanel...
The weakness is not totally useless. I am using it to remove aftermarket painted pinstripes on one of my cars. No damage to the factory base/clear paint finish.
View attachment 1655911View attachment 1655912View attachment 1655913View attachment 1655914View attachment 1655915View attachment 1655916View attachment 1655917View attachment 1655918View attachment 1655919View attachment 1655920
A second nomination for a lye bat. It’s much superior to Easy Off.
After stripping and after repair/polishing.
Hey Mike...I know this is an old thread...how did you apply the everbrite...and is it still holding up?
I want to add another trick to this thread: screw/fasten long pieces of trim to some scrap wood strips to prevent any trim from getting sucked into the buffing wheel and damaged!
Mike
Good trick...I will keep this in mind...how did you apply the everbrite? They make an aresol or brush on
It can be brushed as I did and it flows out very well. I haven't tried spray but, it may be superior like most products seem to be.
Mike
Mike
How would you attach peak mouldings to the board. I have some that need help. Thanks.
If the trim is large enough to hold/handle securely skip the backing. Long, skinny pieces without holes can be strapped on a board with any material that won't damage the finish in areas that have been worked over. Improvise!
Mike
Hey Mike...some time ago you sent me trunk lettering dimensions....they were spot on!! Thanks again for your help!
Ooh! Looking good. I think you have a little bit work to finish assembly. Keep us posted on your progress.
Mike
