twecomm
Recently had problem with L rear brake lamps not woking when braking on my 66 Charger. Looked over the schematics and decided had to be a problem with the turn signal switch which is original to the car. Shop manual has little detail on the switch or schematic of the switch. Thought I would do a write up on the process of removing steering wheel and the repair of the switch. The info on the switch is likely applicable for many other same era Mopars. I did purchase a proper replacement, but since I was able to repair the original, I'll just keep it with my spare electrical parts in case ever needed.
Here is a link to DropBox where you can down load the PDF I created. When you go to the link, it can be viewed or downloaded by clicking the down pointing arrow in upper right bar. Another window will pop up asking to join or sign up. At the bottom click on "Or continue with Download only".
Hope it helps someone out..
Dropbox
Dropbox
