66 Charger, Turn signal repair
twecomm
3:40 AM
Pittsburgh PA
Recently had problem with L rear brake lamps not woking when braking on my 66 Charger. Looked over the schematics and decided had to be a problem with the turn signal switch which is original to the car. Shop manual has little detail on the switch or schematic of the switch. Thought I would do a write up on the process of removing steering wheel and the repair of the switch. The info on the switch is likely applicable for many other same era Mopars. I did purchase a proper replacement, but since I was able to repair the original, I'll just keep it with my spare electrical parts in case ever needed.
Here is a link to DropBox where you can down load the PDF I created. When you go to the link, it can be viewed or downloaded by clicking the down pointing arrow in upper right bar. Another window will pop up asking to join or sign up. At the bottom click on "Or continue with Download only".
Hope it helps someone out..
Dropbox
Nice work!
I'm grabbing a copy.
Both mine work fine but my Plymouth doesn't reset following a turn.
I'll look into it sometime
Have to log in or sign up to download. May have to have the daughter help with that. I should have a copy of this in my 66 Charger file for when, not if, the turn signal unit needs replacement. Thanks for posting.
Pm @twecomm and he can email you
You don't need to sign up or log in to download the PDF, Just click on the down facing arrow as shown , 2 nd character from left at upper corner of the screen. Another pop up window will appear asking for you to log in or sign up. Click at bottom of that second window to where it says "Or continue with download only" It will start the download into your downloads folder on you computer..
Thanks, I am now having the identical problem, although it was fine when I installed a new switch a couple of years ago. I was able to download your instructions, so hopefully I will be able to fix this over the winter.
Hi qkcuda, Note that that write up was about how I repaired the "original" turn signal switch in my 66 Charger. Although the electrical functions of a currently available reproduction type switch are similar electrically, there are mechanically different. Good luck with it...
I bought the one recommended by slant six Dan, supposed to be the best replacement available at the time. The original is long gone, so we'll see how it goes.
I have been in contact with Dan. He was hopeful to be able to order switches again. With the tariffs and trade issues now, that may not happen. I bought one of the aftermarket switches from a Mopar parts warehouse and it didn't work properly. If I use the turn signals, I loose one of the brake lights. I was lucky enough to buy w used column from a 65 B body that had a solid feeling switch in it. I have removed it. I need to test it before I install it.
Tarriffs & trade issues... Hmmm, sounds like they are sourced from China ? Oh, right, they are the folks who make everything now..
Dropbox
Very well done. I replaced my turn signal switch a few years and all functions work as expected. Your detailed photos and explanation will help others I'm sure. Thanks for sharing your hard work with the Forum.
