Does anyone have a trick for loosening the front bleeders on a 66 coronet?The location they are in I cannot get a wrench on them.What kind of wrench do I need?
After you build or buy a wrench,If its stuck tight, careful dont twist it off.
You can apply some heat to the bleeder with a propane torch turned down LOW. dont fry the brake hose or the cly.
Sometimes they will have some rust/crud in the hole and will need a piece of wire ect to get it open to bleed
I stand corrected .I was measuring drums on the car not taking into account they are 1/2 in bigger all the way around to fit over backing plate.So I have 10in drums.
