66 coronet brake bleeders
66 convert
4:44 PM
Cherry valley il.
Does anyone have a trick for loosening the front bleeders on a 66 coronet?The location they are in I cannot get a wrench on them.What kind of wrench do I need?
I had a similar problem on my '69 Road Runner. I heated and bent a wrench to fit.
That's why they make numerous brake bleeder wrenches, out there in the mechanical repair world.
After you build or buy a wrench,If its stuck tight, careful dont twist it off.
You can apply some heat to the bleeder with a propane torch turned down LOW. dont fry the brake hose or the cly.
Sometimes they will have some rust/crud in the hole and will need a piece of wire ect to get it open to bleed
My 66 coronet has 11in drums up front .Does any one know what the bore size for the front wheel cylinders would be.
I stand corrected .I was measuring drums on the car not taking into account they are 1/2 in bigger all the way around to fit over backing plate.So I have 10in drums.
