5.7 or 6.1
stick or auto....stall converter rpm?
headers or manifolds?
lots of things you need to know to suggest the RIGHT cam
Just pointing this out......the belt needs to wrap around the water pump pulley a lot more than what you have in the pic!
do you have a pic for reference? this is how I bought it and how previous owner was running it. Will it help once power steering is added? I haven't touched the belt system from where it was pulled out of his vehicle when sold....
thanks for the heads up but I need to see what it needs to look like...??? and I WILL be adding power steering...
If he isn't running a mechanical fan that will probably be enough to run the pump. If he wants to run a fan, then yes I agree with you. If he runs it that way with no overheating issues and no squeal or excessive belt wear then it should be ok. I would just monitor that going forward for a while.
