67 coronet reverse lights
Davespa
2:47 AM
Orlando
looking for a wiring diagram that connects a 1970 383/727 auto that I put in my 1967 dodge coronet 440, it was a 318/904 car. issue? I have the 3 pin neutral safety switch, the center wire I know goes to starter relay, got that.. the other two wires go to the reverse lights. Question is? Where do I run the wires from the NSS to What part of bulkhead wire/harness??? Thx for any help!!
I believe your car has the reverse light switch on the steering column. Just run the two wires from it down to your outside terminals on the neutral/reverse switch on the trans.
Thanks Man!
one last thing? if I run the two wires from switch to NSS, to reverse switch... where is it getting power from?
THX!
I'd have to look at a wiring diagram - ill get back to you.
The switch completes the circuit. One side should be hot going into the switch. Any circuit controlled by the ignition switch will work. Or just wire the nns to the proper starter relay terninal and leave the existing reverse wiring alone. There is really no reason to move it unless you have moved the shifter location.
The existing wire going to the transmission should be a ground wire for the nss.
Thx! Sorry hadnt got to check yet, soon
hey thx for the help! I got another dumb question...lol turn signal flasher/hazard.... location?,got dash out and cant find it, im pretty savy, but can not locate it.. thx again!
