The R/T actually came on 68 Coronet R/T's with the optional Rally cluster.... Mike Ross reproduced them based off my original piece...If you have one that says R/T, that’s an aftermarket piece. The two that came from the factory are the ones in the two pictures that I posted this morning.
My cards have the date stamped on them, so guessing they all were if the guys doing the stamping was having a good day, lol!I have to check my original panels and report back, but I think there was a date code stamped on the back of the card. I would have reused my buttons but it looked like they were peened over on the back so I had to get repros. From what I've seen, most of the repro panels didn't include the square buttons. Possibly some do now.
So... are the early rear view mirrors the same as a '67 mirror?
Thanks. I just read in another thread that there are differences in the tail lights. I'm not sure if it's the housings, or lenses or what, but said something about having "protector tabs" on the early ones...The one on my green car was the same as a 68 mirror, but without the outer vinyl band.
I have one in my 70 Charger R/T SE. I got it from a 68 Coronet R/T.The R/T actually came on 68 Coronet R/T's with the optional Rally cluster.... Mike Ross reproduced them based off my original piece...
But a 70 Dash doesn't have the square hole... How did you attach it?I have one in my 70 Charger R/T SE. I got it from a 68 Coronet R/T.
It fit in the screw hole with a bit of pressure.But a 70 Dash doesn't have the square hole... How did you attach it?
Never seen one with a seam down the middle. Most likely it is a upholstery shop special or home garage job.Ok, new question. My '68 has a vinyl top with a single seam down the middle. I this real or a replacement? Legendary only makes the 2 seam tops for them and says they are the correct top. Anyone else have one with a single seam right down the middle?
My 68 Charger (SPD 1/22/68) has the no tab tails lights as well as the rivet.
As far as the roof, mine has 2 seams on each side.View attachment 1717255View attachment 1717254
