cdr
ALL my pulleys are 68 big block a/c,,the power stg pump is for the rack& pinion,you can use the stock pump & brakets,,i have the 4 belt lower pulley & a 4 core radiator,my fan is an 18 in,,fan clutch is a jaguar 2765 hayden,,lots of mopars run this set up,the ac brakets are from bpe,i also have the 90 amp 1988 dodge denso alternator,i will sell the pulleys & they will work with ac,just no mechanical fan.if you need help i will get you the part #s for the steel pulleys & brackets that will work for you.Are the pulley that you are selling the right ones for the A/C setup, I could always do some machining to it? How many grooves does the crank pulley have? The reason I ask is because I have a three groove using one for water and alt another for power steering with one left (the one closest to the block) and I'm crammed for space (fan would hit a 4 groove). I'd really appreciate any pics or even part #'s for the pulleys you used. PM me a price on the pulleys if they are the correct ones for A/C. Thanks
I checked that link "don't like they're setup" they show one belt on the alt and not very much contact either. I have a 100 amp alt that squeals the belt, I'd like to have two belts on it like yours. Did you have to go with an aftermarket power steering pump?
the 69 brackets will work also as long as the are for AC
