68 coronet hemi swap in Az
penski61
6:43 AM
mesa , arizona
What going on everyone here is the 68 coronet I bought a few weeks back , had a 383 and 727 in it that ran ok but was in need of a rebuild . Pulled the motor and trans now the plan is to install a 6.4 that is currently being built with forged internals amd mmx cam , 8 speed trans and custom 4 link with a 35 spline 9 inch.
EA3C4461-569B-49E7-A028-4014F9BEEAF7.jpeg 4A9B0D19-5F3A-4550-9E20-29C068863D81.jpeg 2105CCF2-5F6C-464A-A334-302DF0521596.jpeg D9D562CC-76B0-476B-BFCA-2C1C1D656E5C.jpeg EDE6FC16-6E46-4F88-8AB5-66396A294356.jpeg 112B3A64-911B-413A-8514-ECC07E68472F.jpeg ED313608-2B93-4C1C-B3F4-5A27AAAC217A.jpeg
Lower axle link mount from ridetech , the other brackets I made. Adjustable upper link mounts and adjustable frame side lowers that will bolt into spring location .
Got the frame cleaned up , old shock cross member cut out , plates cut out and burned in , then got the holes drilled out for 1.5 Dom and ran the tubing thru . Pretty good start on the 4 link
685CC75E-AD0C-4DB3-8009-9F3706FCBBD5.jpeg 8A31B534-0528-4A97-8D78-4994D7CB3EB0.jpeg 00839AC4-C10B-4F7B-BDF4-C06FDB006EC9.jpeg EF67CA5D-18C9-4948-9DFC-5E43C865B7B4.jpeg 508F7DB6-F622-4742-A275-3745FC2B08DF.jpeg DFB155EE-F6C3-4120-A642-AFBFE9241CDE.jpeg
Nice! My favorite year for Dodge b bodies. I had a rock solid one some years back that I sold to help pay for storm reconstruction when I lost most of the pole barn. Have tried a couple times to buy it back, but no luck so far.
Upper frame crossmember and link mounts burned in . Now just have to wait on the axle housing
Made up some sub frame connectors out of 1.5 square tube and bent some 3/16 flat stock so it could tie into the seat braces (just need to re drill the holes . Form fitted 3x3/8 flat bar to fit inside the tunnel to make up another cross member for rigidity .
979D7610-08F4-413B-94CF-1C221BD34E18.jpeg 317BA411-393B-4BCB-8750-0968CCD23103.jpeg 63650572-714D-4B24-ACE6-63D719E574B7.jpeg
Right on man, keep the pics coming. Are you gonna boost later?
Are ya gonna put some angles to connect the frame ties to the seat mounts? It’ll make that tie stronger if ya do.
I probably could have but should be fine the way it is plus ill probably be running the 1/2" supply and return fuel lines down the side so it will make it easier with no gussets there
Did you bend over the flat bar to weld to the ties?
yes the flat bar is bent over the sub frame connector on one , the other bent in front of the sub frame connector
Some updates . Still waiting on the motor which should be done this coming week hopefully . Decided to sell the 8 spd and shortly after found a t56 magnum setup for b body with 300 miles on it , owner installed but has a back injury and couldn’t safely drive it in his opinion . Got the 9” housing and pretty much finished up the 4 link
AA010FA7-D6AA-41A8-AA1E-3B75C6297B44.jpeg E1000A7B-53E2-46CC-BF18-7D73A03919AD.jpeg 38B82351-2AAB-411F-90CB-D39C32FA76A6.jpeg
Nice the T56 is much better for fun and ease of install!
Forgot to post these but made my own clutch pedal and modified brake pedal from the auto assembly
2B3A9C4E-0C6E-4282-9E38-4C1D9831062F.jpeg 02888D20-7AA7-48E9-9D84-A11D6AF5D6EB.jpeg
You're doing a beautiful job,I'm going to do the frame
connectors soon.
well the t56 magnum I paid and waited for fell thru , day before it was supposed to ship out the seller said he found something in the oil and refunded my money . not sure if thats actually what happened but ended up finding a mopar performance t56 magnum brand new so I should be getting that shipped out Tuesday
