68 gtx A1 26 radiator on fender tag with 22 opening
Heating, Cooling & AC
  1. 62MAX
    62MAX Well-Known Member
    1,573
    1104
    Jul 21, 2008
    PA
    Local Time:
    10:44 PM
    Here s the original tag from my old 68 383 GTS,no inspection mark and the font is identical to the tag in question,I would lean more to the miss stamp than fake tag.[​IMG]
    • Like Like x 2
    • 69Coronetrt
      69Coronetrt Well-Known Member
      3,030
      1932
      Jul 17, 2008
      Harlan, IA
      Local Time:
      9:44 PM
      again......what one plant did or didn’t do doesn’t translate to another. Hamtramck is different that St. Louis.
      what was coded, when it was coded and even where is was coded on the tag varies by year, plant and even time of year.
      • Like Like x 1
      • eldubb440
        eldubb440 more miracles than Jesus FBBO Gold Member
        7,380
        17012
        Jul 17, 2008
        South Jersey USA
        Local Time:
        10:44 PM
        theoretically speaking, and not saying this is the case with your car......
        it is possible that a rusty or totaled, numbers matching GTX, was re-bodied with a satellite; using all of the matching GTX stuff..... Only problem would be the order number on the original GTX tag wouldn't match the body stampings on the replacement body; so someone had to make a duplicate GTX tag with the new order number. (and they messed it up with the 26" code)
        the only way to prove the body, tag, and VIN all match is with a build sheet.........and I'm sure they can fake those too
      • 72golddustermike
        72golddustermike Well-Known Member
        233
        95
        Apr 13, 2012
        n.east arkansas
        Local Time:
        9:44 PM
        All i am asking is it possible they mis stamped the fender tag.
      • 69Coronetrt
        3,030
        1932
        Jul 17, 2008
        Harlan, IA
        Local Time:
        9:44 PM
        Yes it’s possible but not in this case.....
        are you not curious as to how I knew the VIN? Post 16.
        • Like Like x 1
        • tnfastback
          tnfastback FBBO Gold Member FBBO Gold Member
          2,471
          5304
          Jul 4, 2016
          East Tennessee
          Local Time:
          10:44 PM
          So if you are going to convert from a 22” to a 26” where can you find the passenger side radiator support panel??
        • eldubb440
          7,380
          17012
          Jul 17, 2008
          South Jersey USA
          Local Time:
          10:44 PM
          AMD sells a 26" core support......... or you get one from any A/C car, even a 318 car
        • tnfastback
          2,471
          5304
          Jul 4, 2016
          East Tennessee
          Local Time:
          10:44 PM
          Is 68 thru 70 B bodies all the same such as Coronet, RR, Super Bee, etc??
        • 72golddustermike
          233
          95
          Apr 13, 2012
          n.east arkansas
          Local Time:
          9:44 PM
          Not my vin
        • moparnation74
          moparnation74 Well-Known Member
          10,506
          18007
          Mar 27, 2014
          OHIO
          Local Time:
          9:44 PM
          Relating to FT's...NO
        • 72golddustermike
          233
          95
          Apr 13, 2012
          n.east arkansas
          Local Time:
          9:44 PM
          That not my vin if you think it matches the last numbers of fendertag.
        • 72golddustermike
          233
          95
          Apr 13, 2012
          n.east arkansas
          Local Time:
          9:44 PM
          Because fender tag and part of core stamping.
        • tnfastback
          2,471
          5304
          Jul 4, 2016
          East Tennessee
          Local Time:
          10:44 PM
          Relating to the radiator support passenger side panel??
        • 69Coronetrt
          3,030
          1932
          Jul 17, 2008
          Harlan, IA
          Local Time:
          9:44 PM
          My mistake and appologies. Sorry. Whoever posted the tag in 2012 must have intentionally posted the wrong VIN.
          • Like Like x 1
          • moparnation74
            10,506
            18007
            Mar 27, 2014
            OHIO
            Local Time:
            9:44 PM
            Ohh I thought you were talking about tags....I didn't see the previous post.......
            The core supports are the same in 22 or 26 for all B's 68-70....Which I think you will agree and the previous post about AC is incorrect
          • eldubb440
            7,380
            17012
            Jul 17, 2008
            South Jersey USA
            Local Time:
            10:44 PM
            there may be minor differences, but all 68-70 B body core supports are interchangeable
          • 72golddustermike
            233
            95
            Apr 13, 2012
            n.east arkansas
            Local Time:
            9:44 PM
            That very well may be the car. Where was it posted? Would like a little more info.
          • 69Coronetrt
            3,030
            1932
            Jul 17, 2008
            Harlan, IA
            Local Time:
            9:44 PM
            it’s the same car.
            I visit numerous boards, eBay, Facebook and wherever for tags. I don’t know where that specific image came from but I’ve had it for “a while”.
            • Like Like x 3
            • eldubb440
              7,380
              17012
              Jul 17, 2008
              South Jersey USA
              Local Time:
              10:44 PM
              I am wrong about all A/C cars having a 26"?
            • moparnation74
              10,506
              18007
              Mar 27, 2014
              OHIO
              Local Time:
              9:44 PM
              Nope...but it is the same core support in my non AC 4spd GTX.....Thats my point....AC core support is no different than a non AC core support 26"...They are the same....
            1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
              By continuing to use this site, you are consenting to our use of cookies.
