If the manifold is aluminum, it's either an original A12 or the EDE CH6. A very good manifold. The meter plates appear to be the '69 1/2, the '70 & later plates have different shape.
Yeah it’s aluminium but has no casting numbers or brand on it. So is the 69 1/2 plates not as good due to the modification? That thin plate is all bent up now. Not super bad but definitely not straight.If the manifold is aluminum, it's either an original A12 or the EDE CH6. A very good manifold. The meter plates appear to be the '69 1/2, the '70 & later plates have different shape.
Why would anyone grind the numbers off? Well it fits in with the rest of the weird things I find on this car haha.So apparently some one ground off the numbers. My set off '70 carbs worked the best. Not sure why.
No idea why. But I know both the OEM A-12 manifold and EDE aftermarket version had casting numbers. I had both. Back in the day, I ground a lot of stuff off, but never off the intake.Why would anyone grind the numbers off? Well it fits in with the rest of the weird things I find on this car haha.
Yeah maybe they just wanted it to look flush. Would have been nice to know what it was.No idea why. But I know both the OEM A-12 manifold and EDE aftermarket version had casting numbers. I had both. Back in the day, I ground a lot of stuff off, but never off the intake.
Yeah they are really stuck on there good. The only kit i could source locally isnt the 6 pack kit. its a holley fast 2300 kit, but it doesnt look like it comes with the secondary metering plate gasket. I have to try hunt that down nowLooks like one of the contributing factors on the plates being stuck was the use of cork gaskets from a parts store rebuild kit and not a Holley. Hopefully the secondary bowls don't have the big nut stuck/stripped.
Check out the needle and seat units. If they are brass with a big jam nut, stay far away from it.Yeah they are really stuck on there good. The only kit i could source locally isnt the 6 pack kit. its a holley fast 2300 kit, but it doesnt look like it comes with the secondary metering plate gasket. I have to try hunt that down now
Holley HO37-1543 Carburetor Rebuild/Fast Kit 2300 Models 350-500Check out the needle and seat units. If they are brass with a big jam nut, stay far away from it.
I did find some 6 pack kits, they werent cheap and the shipping killled it for me. Hopefully this kit i am gettting does the job otherwise this poor man will have to pay twice.Back in the day, was able to get the Holley 6 Pak kits. They had the different versions of the end carb meter plate gaskets. The meter plates were a separate purchase. I was lucky to have a Holley distributor warehouse about 20 miles away and had any part I wanted. The Holley 2300 kit that I got for my oddball modified 500 CFM center carb was not even close to the 6 Pak kit.
If you hose those down with carb cleaner and let it soak in, those plates will peel right off.I have started the tear down on the carbs. I have found they had the secondary hose blocked off. Is that a common thing? The fuel nuts were all stripped so i will have to get new ones of those. The metering plate was stuck on there and to get it off it’s now bent. If I don’t go with promaxx are they pretty common to buy? Also can anyone ID the intake. There are no markings
Nice. I will do that tonight.If you hose those down with carb cleaner and let it soak in, those plates will peel right off.
It looks like it was sanded and polished, possibly? I've used acid to brighten cast iron before, but not sure on yours.Nice. I will do that tonight.
Any advice to bring that aluminium manifold to look a lot better?
I had an AVS done locally here, and it was about 230 for it. He puts them on an engine that he has on a run stand and dials them in for you. He calls you up and lets you hear it running and idling, revving, etc. I was happy with it. I would say in your area, 300 US would be a fair amount, but a question came to me while writing this, does he replate them for that dollar amount? If so, that doesn't sound too hateful.so ive just bought the Pro-Max metering block, throttle base, jet plate kit, lower and upper hose kit. Now i play the waiting game with shipping and customs. Ive spoke to a guy in Aus who replates carbs. seems a bit pricey to get them done though so i will shop around first. Charges $600AUD/carb bout 400USD.
