westie47
What power steering pump do I have? I need to order new hoses.
			Thanks!Saginaw power steering pump.
As for your pal nut issue, on the last resto I did, I merely cleaned the nuts up and used this (or something similar from 3M, since the product specs don't give a diameter):View attachment 904467 View attachment 904468 View attachment 904469 View attachment 904466 So, I’ve had the Coronet home for a week now. I’ve settled on my plan of attack. Like I said previously, the car was running when I bought it, but since I’ve been home, I haven’t been able to get it to start. I’ve basically ordered everything new for under the hood...wiring harness, electronic ignition, coil, plug wires, relays, etc. As you can see in the pics, the salt air hasn’t been nice to the car, everything is covered in surface rustAlso, the wiring was a complete mess! I figured it’s best just to start from scratch. My only deviation to the original plan is that I’m now going to pull the motor/trans, clean it up, re-gasket, paint and throw it back in.
Here’s some pics.
I also pulled the grill and tail light panel out to clean them up. There’s a lot of green mould/mildew on everything. Also, the tail panel was painted with a brush at one time lol. Everything is in good shape, there’s only a couple of broken posts on the tail panel. Since it’s just going to be a driver, I will try polishing it up and painting it myself.
I appreciate hearing any advice/experience in this regard.
Does anyone know where I can get these pal nuts? They look like they had some sort of rubber gasket or insert. Mostly all rotten away.
I'll try that, thanks!As for your pal nut issue, on the last resto I did, I merely cleaned the nuts up and used this (or something similar from 3M, since the product specs don't give a diameter):
3M Calk Strips Black 60 Strips 1 ft each Rubber Caulking Material 08578.
wrap a piece around each "pin" and tightened the nut, squeezing out the excess, which forms the seal.
It's not a state secret lol, actually I was quite proud of the deal I got. He was asking $9500 Cdn, but told me on the phone he was into it for $7800 Cdn. The ferries to and from that island were about $400, so I went with $8k. When I asked him what the take it home today price is, he said $6000 Cdn, not a penny more...just like we discussed on the phone. Well, he must've gotten me confused with someone else as we never discussed price. lol I said, ummmm, sure, since I'm here..I'll take it.Thank you for being thoughtful enough to tell us the purchase price. It always annoys me when people come online to tell about a new project but then clam up when asked about how much they paid. It helps others to determine value when contemplating a future sale or purchase.
Yes, pull the motor mount bolt on the side you need to lift and loosen other side bolt . It should swing up enough to pull header.View attachment 905509 View attachment 905510 I started getting everything prepped to pull the motor and trans...first roadblock was that the center drag link went through the driver side header....I got a pickle fork but one of the tie rod ends absolutely refused to pop...I don’t think any of these parts have ever been replaced!
I still can’t get the headers out, can I lift the engine slightly? What’s the secret to B body headers???
There should be a fender nut there.I got the battery tray blasted and painted but not sure how to attach the upper brace to the inner fender...there’s a square hole on the inner fender and my battery was never attached there when I got the car.View attachment 918570
