`70 road runner, FC7, 383, 727 It`s waited long enough, finally time to get it done.
Got the door straightened, skimmed and sanded down ready for epoxy.
Judging from the inside corners I was pretty sure the skin was not rusted out but you never know what might be hiding under the layers of paint. I am once again happy to see clean metal, just a few small pits and a number of dings and small dents to fix.
It's time to get my hinges rebuilt as the new pin and bushing sets just arrived and I am going to need them to hang the doors soon. I have the full set still bolted on the doors plus some spares from parts cars so I'll pick the best ones. Anyone else NOT use the bushings and instead just weld up, re-drill the holes and install new pins?
I used the bushings but here’s my thread if it helps any
Door Hinge Rebuild
Thanks. I used the bushings in the upper as they were factory but I was able to just tighten up the holes in the lowers and install new pins as they were not very worn.
Inside of passenger door wasn't as clean but still only surface rust. 15 minutes with the bucket blaster and it's all clean and ready to spray.
Inside of passenger door and outside of drivers door shot with epoxy. Once the passenger door dries I'll flip it over and strip the outside of it.
Passenger outside is not as nice as the drivers side with a bunch of dents and filler. It has a few rust spots in the lower front corner that looks like it will blow thru and need a small patch welded in. It's still WAY better than any other old '70's car I've worked on.
Got the patch welded in and ground then started working on the dents, still a couple more hours work to get it straight.
I usually don't buy NOS parts mainly due to the cost but also because my cars are just drivers. I did find these wheels cylinder kits, $26 for both including shipping and a carburetor modification kit for the factory Holley for $24.50 shipped. The modification kit is just a different squirter and pump cam but I thought it was cool.
Working on rebuilding the rear wheel cylinders. I ordered a cylinder hone off Amazon- description said fits 3/4"- 2 1/2" but too big, back of package says fits 1"- 2 1/2". :BangHead: I will return it and just ordered another one, hope that one fits.
