Beep!Beep!
Just the back half behind my seat, even removed under hood barsWow, great score, those parts are gonna come in handy!! Is the cage staying in the car?
The 509s are heavily ported and have the adjustable rockers if you scroll back you can see the ports but I'm using unported 6bbl intakeDo the 440 and use the better heads, wedge guys will which heads are best. Compression 10 to 1 a hair more?
Ok so do you know what kinda idle it would be most of my experience is factory camsThe TRW 2295 pistons are listed ~10.3 compression with an 88cc head. Granted a lot of other factors (head gasket thickness, actual head cc, etc) dictate actual compression but that's a good baseline.
Crane cam ZIP-510A-C --- 254 / 254, 112* LSA, .510" gross lift.
Not sure if that's the same as your ZIP-510-ANC or not
Thanks nice to know comp.ratio ball parkThe TRW 2295 pistons are listed ~10.3 compression with an 88cc head. Granted a lot of other factors (head gasket thickness, actual head cc, etc) dictate actual compression but that's a good baseline.
I lied the 413 according to motors manual stock bore is 4.1875x3.75 stroke ,the bore measured 4.230 what cubic in. Would that make itAs you can see adjustable rockers and porting on the 413. will that be of much benefit if I use my edelbrock 6bbl. Intake because I'm not going to port it out and the lifters are hydraulic. Would it be better to use my 906 heads? The cam in the 413 just has a 29 casting have no idea what grind it is. The timing gear gotta go mopar plastic. The engine was packed with grease doesn't show wear maybe run a pass or two bearings, lifters, I can still see honing marks in cylinders.Lifter has vl-8 on it. I'm going to give you low down on 440 looking for input on which one would be the right fit for this car .Thanks
View attachment 944232 View attachment 944233 View attachment 944234 View attachment 944235
Sorry didn't see your last question just the back half of the cage the rest had to go not flexible enough for thatWow, great score, those parts are gonna come in handy!! Is the cage staying in the car?
Have another question looking at summit they have several options for main &rod bearing, has anyone one used king brand,mains $80 rods better priced than others claim to be for performance engines? Also piston rings type of material brand good and bad? Thanks
Mechanical linkage, 500 cfm outboard carbs, and a 500 cfm center, all w/accelerator pumps, is that what you are referring to?Not commonly known, Holley made a set of carbs for the six pack with side floats and metering blocks so you could change the jets. Best part was all were pumpers, no vacuum secondaries here. I set one up for a friend in a sixpak Bee, absolutely stunning throttle response. I don’t think they made those for long, early 70’s only I believe.
