Joeyms
Good morning, I have a 70 Roadrunner with some new electrical issues. First, the gauges started acting up on a rally dash. Temp would run correct and then peg out. Same as oil pressure. Gas gauge worked fine. I changed out the voltage limiter, then the problems really started. Took the car out for a test drive and the three gauges went to half. The gas tank was full. After three miles all three gauges went dead. I checked the fuse box and have no power to the Accessory block, the heater block, and the instrument block. Checked with a test light from the back of the fuse box. No power coming in. I also have no instrument lights, ( bulbs are good). Headlights and taillights work, as does the dome light. Were do I look for the loss of electricity to the fuse box. Appreciate any help from you guys with the electrical knowledge.
Thanks
Joe
70 rr
71 Satellite
07 Dodge 1500
Thanks
Joe
70 rr
71 Satellite
07 Dodge 1500
