1967coronet
I ordered a replacement drive shaft slip yoke from {Dennys drive shaft}. The barrel on it is 6"
My old original one is 7" they both are the small joint 7260 series and the U joint fits correct.
On the 727 tail housing my output shaft hangs out a little aprox 1" past the housing visable with the seal off.
My question , Is 4" of slip yoke on that output shaft enough ? 3 " inside the housing and that last inch is on the output shaft that is exposed past the tail housing end. with the seal installed I will have 2 inchs of barrel sticking out of the dust boot.
The car is a 67 coronet 318 car switched to 383 and 727 so I am not sure were the old 7" yoke came from.
Thanks.
Thanks.
