193rdsow
I have a 340 4 speed Cuda with a Predetonation issue. If I set the timing at 5 degrees BTDC, whenever I hit the throttle hard it brings like crazy. At 10 degrees ATDC it's not so bad. The engine is a low compression '73 motor that's got a cam slightly more aggressive than stock. Is there anything else that can be causing the Predetonation other than the lousy 93 octane gas? Should I run cooler plugs? Anything else I should try besides Turbo blue and retarding the timing?
